Carpet holders (below the door) Rocker Panel.
https://forums.aussieveedubbers.com/threads/109264/carpet-holders-below-the-door-rocker-panel
Pacific-Dubber ·
Hi has anyone got a drawing for the rocker panel carpet holders (on top of heater channels) so I can get some made.
Best picture I can find is http://www2.cip1.com/ProductDetails.asp?ProductCode=TAB-400-341
Ian
psimitar ·
For what year? Early bugs use an L shaped piece with the clamping edge having the exposed edge doubled back on itself facing downwards.
later ones are a strip with the open clamping edge facing out towards the door. Must use a strip of fibreboard or something stitched to the carpet to hold the carpet in place. The open clamping edge is also doubled back on itself so there isn't a sharp edge facing you.
for the early one the open edge sits about 3-4mm above the heater channel/sill.
Pacific-Dubber ·
psimitar wrote:For what year? Early bugs use an L shaped piece with the clamping edge having the exposed edge doubled back on itself facing downwards.
Model:
It's a 67 Deluxe with narrow Nose & vertical spare model. Sorry no new pics all prior to repairs, my internet is slowwww due to 4G
upgrades.
psimitar ·
Yea, so this is a cross section of the carpet clamp. The strips length is about 15mm short on each end of the door aperture. Top section is only about 15mm deep and the upright bit that spot welds to the heater channel/Sill can be measured from your channel and add a few mm to allow for the gap needed where the carpet is clamped 🙂
modnrod ·
Have a chat to some upholsterers about various options.
I can understand wanting to keep it stock for a "proper" resto, but most cars have a strip of something bolted to the sill to hold the carpet edge down (just one idea).
I'm not suggesting that is the best way, or the correct way, but personally I've often found it the easiest.
Upholsterers do this daily for a living, and would know all the tricks both ways.
Free plug for one I have spoken to a couple of times, Brad knows way more than I ever will about interiors........
http://busnbug.com/
Pacific-Dubber ·
I'm hoping for a good drawing so my sheet metal man can fold them up. That would be really good. 🙂
psimitar ·
Pacific-Dubber wrote:I'm hoping for a good drawing so my sheet metal man can fold them up. That would be really good. 🙂
Um, the diagram of the clamps profile plus you doing a few measurements is all you need for a sheet metal guy to know em um within 20mins 🙂
Modnrod is right. You could use some rivnuts in the channel top so that you can bolt some nice polished stainless strips on top of the carpet.
Pacific-Dubber ·
I guess that I'll make a diagram when I go measure a car but the profile is what I didn't have worked out as you destroy the piece when you cut it off.
I am going to use a two pack glue to re-attach the strips. 3M's Scotchweld does the job very well with metal to metal. I have used it to glue in a ute floor previously. It isn't cheap but it is very good.
Often thought about gluing a car up over welding. Trouble is most people dont have confidence in space age glues 😉 .
I'll try & post a diagram tonight (now I know the correct profile) *stay posted.
Ian
VVDS have them in stock 02-9789-1777 unless you really want to make them
Pacific-Dubber ·
Well here it is folks,
Sadly 0.5mm black sheet is hard to come by in Australia (Zincalume is sold in 0.55mm) so the next size is 0.81m. I will make mine from the thicker guage as I have a large sheet of it.
Ian
HappyDaze ·
Zinc seal is available in 0.55, and is easy to weld [if you decide not to glue it].
The 3mm bend may be tricky, but not impossible. If you feel like a trip up the hill to the Highlands, I could 'have a go' at it. I can get hold of 0.55 Z/S.
Cheers, Greg
Pacific-Dubber ·
HappyDaze wrote:Zinc seal is available in 0.55, and is easy to weld [if you decide not to glue it].
Cheers, Greg
Thanks for the offer Greg,
I'll see how my local guy goes with making a few up. If no joy there, then I'll come over.
Ian
Easy to purchase new
