orig. purist one or blocked off on shroud (no exit tubes)?
waltermitty ·
not purist but I want a non modified non exit tube OG shroud to fit TP tinware will have an external cooler but I believe the 181 has dog house as well so that would be optimum >
What you got?
M
bushed ·
will have to check in the morn M8
waltermitty ·
If I don't ask you will never know.
Mitchell
bushed ·
mine is modded...neat welds.... but can do the doghouse
have other tinware galore
thanks for asking
waltermitty ·
bushed wrote:mine is modded...neat welds.... but can do the doghouse
thanks for asking
So is yours a stale air modified?
And do you have a non stale air doghouse shroud available?
see if this works its a dog house shroud without heater outlets to the breastplate
grogy ·
Hi. Sorry. I was mistaken. I only have standard 1600 doghouse
waltermitty ·
Thanks for looking.
B
U
M
P
bushed ·
put a fancy 36 hp one in Mitchell
waltermitty ·
bushed wrote:put a fancy 36 hp one in
bushed wrote:put a fancy 36 hp one in Mitchell
I have a scat 36 hp aftermarket with dog house. Factory 36s don't have a doghouse.
Although the scat shroud is reasonable they don't cool as well as a factory dog house but all factory dog house shrouds have stale air outlets and i want the look without them.
I have also read that factory shrouds are designed differently for the stale air out lets and removing them created turbulence in the shroud and results in less cooling especially around cylinder 3.
So the best option for cooling with a dog house and no stale air is a thing shroud and or a Mexican fuel injection shroud.
Also a factory shroud will allow me to install the thermostat flaps locked open which will better direct the cooling air to where its most needed.
Mitch
Old Dubber ·
So this is a 36hp fan shroud on a stale air 40hp engine, converted to 12volt???
waltermitty ·
It might be , no dog house for oil cooler i need dog house.
The fan on a 36 Hp shroud is narrower and blows less than a 40 HP shroud.
I want non stale air dog house factory shroud, rare but nice.
I am back in Indonesia in a few months and have been putting some feelers out there.
I am hopefull that with the best combination of factory tin etc well installed i can get the best possible cooling without going to external coolers. simple clean smart.
bushed ·
a 40 hp fan will fit 36 shroud and whine less whatever u do...
details r interesting value
waltermitty ·
bushed wrote:a 40 hp fan will fit 36 shroud and whine less whatever u do...
If you have a 36 hp doghouse that will fit a 40 HP fan and does not have sale air SOLD!!
