Aussieveedubbers 路 Tech Talk
Drop spindles and speedo cable -no room
https://forums.aussieveedubbers.com/threads/109382/drop-spindles-and-speedo-cable-no-room
Trendy 路
Has anyone had issues refitting speedo cable to drop spindles? There is no give in the cable on turning and looks like cable will sheer off.
What is a solution?
adlbeetle66 路
What brand of drop spindles are you using?
I used empi ones, and they were fine for me... 馃檪
Smiley 路
Perhaps you need to fit a slightly longer speedo cable?
One from a super should do the trick.
Smiley 馃檪
kylandpl 路
I have EMPI spindles and no issue with mine either.
Have you checked to make sure your cable is routed right and there is no slack anywhere from speedo to spindle that would give you the "missing" length?
Trendy 路
Spindles are fitted proper now. There is enough length in cables.
Dah!
Now tell me how many shims/spacers should I put into pins. Originally had 8 in each. New pins came with 10. Measured it all up but still a bit slack.
adlbeetle66 路
Models vary.
So this is a 1960 - right?
1303Steve 路
Most workshop manuals have a chart to tell you how many shims are needed, found this one
1303Steve 路
edit sorry, just search "vw link pin shim chart" and you will find heaps of images that will help you get the correct adjustment
Bizarre 路
Link no work - but try one of these
https://www.google.com.au/search?hl=en&site=imghp&tbm=isch&source=hp&biw=1366&bih=683&q=vw+beetle+dropped+spindles+shim+chart&oq=vw+beetle+dropped+spindles+shim+chart&gs_l=img.3...1445.14393.0.14747.27.19.0.8.0.0.289.2845.0j9j5.14.0....0...1ac.1.64.img..14.13.2604.LxbsjP-x9B8#tbm=isch&tbs=rimg%3ACTAtKCRJ9G6SIjjIKFpjqx6rUPgDhWFOAJHF7A0CCPU38hAQuOSKsalVIlmt_1Kl9M0MVFN_19dNRPRszVydt5BgDXwioSCcgoWmOrHqtQEfMBZD4UI7oMKhIJ-AOFYU4AkcUR3NZnhA7zQ0MqEgnsDQII9TfyEBGBc1Stcyo-ZSoSCRC45IqxqVUiEU3lpCLh8lqOKhIJWa38qX0zQxURP5eO_1Jy7zBUqEgkU3_1101E9GzBFYIc8SFVikxyoSCdXJ23kGANfCEZgdxABgIRjK&q=vw%20beetle%20dropped%20spindles%20shim%20chart&hl=en
adlbeetle66 路
http://chircoestore.com/tech_articles/?p=225
Measure your offset then go from there!
