Aussieveedubbers · Weekly Deals
Kuch's Laser New Website, New Products
https://forums.aussieveedubbers.com/threads/109414/kuchs-laser-new-website-new-products
Kuchster ·
Kuch's VW Parts, Modification Gear and Accessories mainly of the Laser Cut variety.
I've got my new website up and running with heaps of new products with more continually being added.
http://www.kuch.com.au/laser
Email or call me for any info.
Thanks, Kuch
waltermitty ·
Nice stuff mate!
Mitch
Kuchster ·
It must be narrow your beam September..!
Type 2 Ball joint late bolt spacing $25 a piece, you can easily drill the 90mm bolt spacing holes for use in early bus. September pricing only.
Kuchster ·
We had a little issue with a group of wheel adapters that were made.
They were tapped with 14x2 thread rather than 14x1.5 thread.
So, I am offering these up as a budget wheel adapter.
Supplied with 50mm 10.9 grade bolts, cut to your own length depending on application which are therefore used as studs.
Ford have a 14x2 nut which is readily available online, suit mag wheels only with the 60deg taper. Not suitable for stock rims with ball seat.
$15 each including 5 x 50mm 14x2 10.9 grade bolts.
Kuchster ·
Adjustable height caster wheel system
Suits both Split and Bay.
A bolt on, adjustable height caster wheel system allowing you to adjust chassis height from 350mm to 600mm off the ground. Includes 1 set of straight and 1 set of swivel with brake caster wheels, all bolts and pins ready to bolt onto your chassis and roll.
$490
