WTB - fresh air seal
https://forums.aussieveedubbers.com/threads/109444/wtb-fresh-air-seal
jakeandco1958 ·
I need the rubber seal that goes over the fresh air box under the windscreen for a 1971 beetle . It seals the fresh air intake to the front bonnet.
grumble ·
This is a square section rubber,measure the clearance from the bottom of the slot on the air box to the bonnet add approx 8mm for compression and measure the length and go to a supplier like Grippy Rubber Products who should be able to assist. This is if you can't get one from Mick's Motors,Tooley Imports,Vintage Veedub etc.
jakeandco1958 ·
Thanks. I went to Clark rubber and found something very similar. I glued the two ends together and put in. I also managed to get some sponge rubber discs and fixed the fresh air dampers
