Hi there. been having issues with the guages in my T4 transporter. At first the fault was intermittent but now the guages are permanently screwed up. I found an online resource written step by step to remove the guages and troubleshoot the likely cause of the issue. (They say these models are prone to dry joint on the circuit board).
Anyhow, the guide says I need to remove the steering wheel to get the gauges completely out. Unfortunately my van has a drivers airbag in the wheel. The manual I found worked on a model without airbags.
I've never attempted to deactivate or remove an airbag in the steering wheel.
Is it a major drama? Can anyone give me guidance on how to do it?
The manual should help with the guages and if they can't be fixed I can always replace them but I've never touched or removed the airbag before. Need tips.
eXraycer ·
