Hi,
After a 6v headlight dimmer relay for beetle as mine had died.馃ゲ Has high beam on indicator stalk as its UK import.
68AutoBug 路
norbert wrote:Hi,
Have You a pic of one OF THESE 6 VOLT RELAYS FAIRLY RARE AS i
grumble 路
I have a couple of these but there are a couple of different ones,can you get the part No off the unit for me please.
Les
norbert 路
Sorry about the late reply, have been of the air. The part number is 3R27. Its a square housing with 5 connections. Will take a picture later today.
Norbert
norbert 路
photo added.
Thanks lee and grumble
norbert 路
bump
grumble 路
Sorry Norbert they have disappeared into space,i will come across them sometime in the future but don't hold your breath.
Regards
Les
norbert 路
Thanks for looking Les
pv370 路
have you tried type 3 6v headlight relay ???
if you post a pic of the terminal side of the relay i can checkout the type 3 ones to see how different they are.
or maybe check the wiring diagrams for terminal numbers etc
