jakeandco1958 ·
I've just fitted a Saas 52mm Tacho which works but needle bounces all over the place. Have tried the following. Made sure it was connected to negative side of coil, fitted a resistor between coil and gauge, checked and changed earth wire, setting on rear is set right. 4 6 8 Other suggestion is fitting a diode. Any ideas?
