Drag Car and Parts
https://forums.aussieveedubbers.com/threads/109653/drag-car-and-parts
mike64 ·
Drag Car and Parts For Sale
1965 Body
Floorpan and Chromemolly Roll cage with a ANDRA pre tec certificate
All Alloy sheet work inside rear $4,000. ono
L/R new outer door skins steel $500 the pr SOLD
Alloy front beam, drop spindles, new king and links, new front discs and Callipers, rose joints, avise adjusters, wheel bearings $1,200 SOLD
Alloy Rear Wing 3pc $200
Fiberglass Stock Front guards $300 SOLD
Fiberglass Wide smooth Rear Guards $300
Fiberglass Front Bonnet $250 SOLD
Fiberglass Stock Rear Lid $150
Fiberglass Flat 4 rear lid with vents $450
2442cc Engine Complete and Running $12,000. SOLD
Race seat, cover and frame SOLD
Fuel tank, straps and frame SOLD
Twin IDA Carbs 51.5 Spanish made ( NO Chinese Crap ) with lots of mods for all out drag use, on Scattrack Manifolds $2000
And much more, just call me or a pm
" SOLD ITEM'S "
2ltr gear box SOLD
Race Harness SOLD
Oil temp and oil pressure gauges SOLD
Fuel pressure reg SOLD
MSD 6AL SOLD
MSD 2Step SOLD
MSD Rev Limiter SOLD
Folks Spool, Axels, Axel Tubes and all associated Gear Box parts SOLD
Steering Wheel, Quick Release Hub and Column SOLD
Engine SOLD
Holly Fuel Pump SOLD
Breather Tank SOLD
NOTE: Rear Rims and Tyres pictured are NOT part of this sale.
NOW SELLING parts of this Separately, if your interested in the engine complete as a runner or the car only give me a call or a pm.
Campbelltown NSW 2560
Call Mike Waldron 0419402752
See full list below
mike64 ·
More Pics
mike64 ·
More Pics
mike64 ·
The List
mike64 ·
More pics
I have FIXED the pictures for you
silver ·
Its a shame you didn't finish it....
mike64 ·
Thanks Dave, Dame i-pads...
Yer wished I had the time to finish it, cost wise it's all there just time is needed.
mike64 ·
Also have had a thought to anyone that maybe interested in the car, I have the parts to put a T1 gearbox back into it, I'll post pics of the gearbox mounts and axel plates i had in it before I decided to go with the kombi box,
All the mounting points are still in the chassie to do this,
If this was wanted this would reduce the price by the cost of the donna 2ltr box, the T2 to T1 nose conversion and the Folks dif, uni's, and axels.
mike64 ·
Mounts and axel plats.
mike64 ·
Front mount
mike64 ·
This gearbox was sold, so you would need a T1 box built with axels and axel tubes.
Adjustable shocks are mounted on the top of the axel tubes.
mike64 ·
Shock mounts and axel plates fitted when T1 box was in.
mike64 ·
More part pics
mike64 ·
N more
mike64 ·
Yep more
mike64 ·
N more
1cut808 ·
WOW!
mike64 ·
mmmm yer that's what a lot mates have said when they found out I was selling it.
Have you made that sticker yet
mike64 ·
All done 👍
blue vizion ·
Bummer!
mike64 ·
Yer I know, I'm going to hear about it for a while yer, but gotta make some room in the shed. 😁
mike64 ·
I'am going to sell this in parts if anyone is interested in something give me a call or pm
I've had more interest in separate parts of this so will sell this way hopefully.
Engine complete as a runner.
The car as a roller, with a dummie axel and wheels on the rear, and will deliver if needed, interstate even.
Cheers Mike.
mike64 ·
2ltr Kombi Gear Box SOLD
Race Harness SOLD
mike64 ·
Have got another car and trailer, need the room 😁
Cheep 65 body, floor pan and Chromemolly roll cage and all the inner rear alloy sheet panels must go as one.
The cage is welded to the floor pan and the body is bolted to the cage and the pan, the alloy panels are all swagged and duzs clipped to the cage and body.
The car and cage has a ANDRA pre tec Certificate with it. $4,000 ono
mike64 ·
Parts are selling great, if there is something you want and your going to Warwick I can bring it with me.
Body n Chassie excluded 🙄
mike64 ·
More parts gone. 😵
mike64 ·
Engine SOLD. Without the Carbs and Manifolds
Carbs are 51.5 mm IDA's on tall Scattrack manifolds. Carbs have had allot of time all sorts of mods done to them. $2000.00
