Bought myself a pair of 36mm Webers to go on my yet to be built 1776. They came with a crossbar linkage but I am not sure whether I want to use it. I have a doghouse fan shroud with heater outlets. Inlet manifolds are unbranded. Anyone know whether a CSP Bellcrank linkage will work with my setup and if so are they any good? Alternative suggestions are also welcome
Cheers.....Wayne
Craig S ·
Hi Wayne,
I don't have heater outlets on my fan shroud, my manifolds are CB Performance, but I can say that the CSP Bellcrank works like a dream on my 36 IDFs, and to my eyes looks much neater.
I'm pretty sure Bizarre used to have a bellcrank linkage on his 1303 as well.
Craig
hulbyw ·
Thanks Craig. I live in Victoria so I need a heater. Anyone out there with a standard fan shroud using a bell crank carb linkage?
Cheers..Wayne
hard to see - but there is a CSP Bellcrank linkage in there
Nice piece of kit - much better than the CB set up in my opinion
hulbyw ·
Thanks Bizarre. Just what I needed to see
Cheers.......Wayne
SunshineKarmann ·
I run the csp bell crank on my 1904 with 36 IDF's. Set and forget, never had to make any adjustments since installation. Have a 36hp fan shroud without heaters. Great unit and well worth the extra $'s.
