baghall ·
Is it normal for the reversing lights to come on when slipping through the gate for 1st and reverse in a T25 wbx, or is my switch positioned wrong?
https://forums.aussieveedubbers.com/threads/109803/reversing-light-question
baghall ·
psimitar ·
Special Air Service ·
baghall ·
It stays on in both reverse and 1st until I take it out of gear.psimitar wrote:Do you mean when you put the box into 1st the light comes on briefly?
psimitar ·
OK, so IIRC the switch has a spring loaded plunger that when in the detent for reverse on the hockey stick makes the switch earth as the plunger is fully extended. So If it's fully extended then it needs to screw further into the gearbox. If I haven't remembered corectly then it'll be the other way around and it needs washers to space it further from the gearbox. 🙂baghall wrote:It stays on in both reverse and 1st until I take it out of gear.psimitar wrote:Do you mean when you put the box into 1st the light comes on briefly?
