200mm 6v fly wheel
https://forums.aussieveedubbers.com/threads/109924/200mm-6v-fly-wheel
jobie ·
Hi All,
I am after a 109 tooth 200mm fly wheel. I don't really want to grind away the bell housing on the gearbox I have.
I'm in Melbourne.
Joel
coletrickle ·
I have a few 180mm 12v oring flywheels?
extremely hard to find these days better off grinding the 4 tabs on the box
bushed ·
may have something but in Qld 4306
jobie ·
Thanks bushed. What you got? 0412 356 triple 5
bushed ·
oh must look in the mornís 6vlt and gd teeth and dowell holes from mem.
bushed ·
is the 200 mm the holes for the clutch?? clutch size would be 180mm +
teeth are right number
dowels are right
OZ Towdster ·
Bushed they are a 6 volt flywheel , ie no o ring groove , 109 teeth , and take a 200mm dia clutch plate
bushed ·
jobie ·
Hi Bushed,
How did you go with looking for fly wheels?
Joel
logan ·
Bustoration in the USA sell them. Also DPR ... if you have look through the vintage speed forum on the SAMBA you will also find a could of other shops in the USA that sell them.
hope this helps
bushed ·
was given a wheel I was told was 6 volt only turned out to be 12 vopt sorry do have clutch now
