petemart wrote:Why not order one directly from Gene Berg?
Just don't want to wait that long for it to arrive 😁
If no one has one or it's to pricey here, then maybe 🤪
vwo60 ·
I ran one of these on my Ghia, but unfortunately it does push on the carb lever the same both sides due to the bend in the linkages, when under load they can move off centre and changes the amount the carbs open on each side, the other issue is they mount on the fan shroud, not exactly a good place as this moves all over the place as it heats up and cools down, I do not understand the high opinion these are held in, I sold it to a friend of mine even though I told him of the issue, he installed it on his kombi and had the same issues, it was removed and replaced with a better design from CB Performance, I run a both the CB performance and the CSP centre pull linkage, both in my opinion are better than the gene Berge item.
Camo ·
Excellent feedback thank you and glad you posted this up. The last thing I want is more issues.
Had another friend call me and tell me to go the CSP centre pull, so will look more into that.
Cheers, Kev 👍
waltermitty ·
Camo wrote:Excellent feedback thank you and glad you posted this up. The last thing I want is more issues.
Cheers, Kev 👍
I got mine from VS its pretty much a CSP copy with bearings etc, it arrived in 3 days and the quality is second to none.
Mitch
vwo60 ·
I run the CSP on my Ghia with good results, does not go out tune as some people claim with centre mount linkages, I had to modify the CSP linkage to fit my engine but works very well, you can see by the picture I had to lengthen the linkage rod on the drivers side due the tall manifolds
petemart ·
vwo60 wrote:I ran one of these on my Ghia, but unfortunately it does push on the carb lever the same both sides due to the bend in the linkages, when under load they can move off centre and changes the amount the carbs open on each side, the other issue is they mount on the fan shroud, not exactly a good place as this moves all over the place as it heats up and cools down, I do not understand the high opinion these are held in, I sold it to a friend of mine even though I told him of the issue, he installed it on his kombi and had the same issues, it was removed and replaced with a better design from CB Performance, I run a both the CB performance and the CSP centre pull linkage, both in my opinion are better than the gene Berge item.
I've run all the linkage types and the Berg is the only one that doesnt go out of adjustment, never moves and had the softest throttle feel.
Sounds to me you may have been running the wrong carb rods, didnt set it up right or had it bolted to a Scat fan shroud.
cnfabo ·
Why not try the pulley system type of linkage...
Fabo
coletrickle ·
Amen Brother
hellbugged ·
petemart wrote:I've run all the linkage types and the Berg is the only one that doesnt go out of adjustment, never moves and had the softest throttle feel.
x2
vwo60 ·
By the way it is attached to the fan shroud, any fan shroud is a major problem in its self. correct rods and mounted to a genuine vw fan shroud originally.
[quote
yes the other bits of the engine NEED to be secure
