Turbo54 ·
Ok all, I am heading off abroad soon and we (wife's car) are going to let the r32 go.
I looked for nine months to find this one, super sad to do it, but it is the easiest way.
22k or negotiable with parts removed and replaced
This car has been meticulously maintained by both myself and the previous owner.
- # 045 of 200
- 224---Kms
- Have both limited Edition printed key rings in the orginal box
- the R32 has never seen the track
- never thrashed
- 90% of the km's are long haul highway. The previous owner use to drive it up from Sydney to the Gold Coast every Christmas.
- Coilovers were fitted by previous owner in 09/07, so as mentioned they'd be around the 160,000km mark. The drivers front needs a rebuild and I have been trying to get this done for a while with little help from KW.
- Misc stone chips on front bar, couple on bonnet and guards as discussed (see sample pics). Small scratch on rear bar.
- BBS wheels have light gutter rash which has been there since I bought it from original owner
- Cat Delete
- Neuspeed Cold air intake
- KW V3 coilover suspension
- HPA Haldex Controller, Haldex unit is a rebuilt controller by HPA I believe. The difference between the OEM and Comp controller is that the comp controller retains the system as a full time 50-50 split and also doesn't disengage the rear diff during braking in bends etc.
The OEM item has a 60-40 split and will obviously disengage during braking
This is my wife daily driver to work and back. I rarely get to drive it and it pretty much puts up and down shepherds hill road every second day.
Amazing car to drive, solid and planted. Anyone who has been in a R32 Mk4 will understand how much this is hurting letting it go.
Replaced;
- Water 'crack' pipe
- main belts
- Water pump
- MAF sensor
- Clutch & flywheel with associated bolts
- Rear main seal
- timing chains, guides & bolts
- 2x Cam position sensors
- Crank sensor
- Vaccum lines on back of motor
- Misc engine bay trim pieces (plastics)
- Battery (Jan 2014)
- Coolant sensor O-ring (Dec 2013)
- Engine mounts (Dec 2013/Jan 2014)
- 6x Spark plugs
- 6x Ignition coils
- Strut mount bushings & Strut bearing
- Front endlinks
- Swaybar bushings replaced
- sunvisors
Brakes;
- New piston boots
- New braided front lines
- Hawk Ceramic pads (front)
- ATE Ceramic pads (rear)
- Tyrolsport caliper stiffening kit (front)
- Braided lines (front)
Extras;
- Misc suspension components
- Misc clips, plastic trim pieces (engine bay & interior)
- Rear number plate light housings
- OEM suspension
- OEM Haldex controller
- OEM interior light
- OEM washer fluid cap
- OEM oil cap
- Misc Globes
- Car bra
Heath - 0434 943 058
SA - 5051
SOLD - SOLD - SOLD
