Sold FS (SA) 1776cc block, Ps Cs and extras
https://forums.aussieveedubbers.com/threads/110041/sold-fs-sa-1776cc-block-ps-cs-and-extras
Dicko ·
Selling for a friend
AD engine block drilled for 1776cc with MAHLE Ps and Cs and Total Seal rings. Block has been line bored (1st time) as well as cam bearing surface. Welded for strength in front of No 1 and 3 cylinders, case savers and deep drilled in front of No3 cylinder. This work was originally done to run a 1776 turbo. 69mm crank ground, external oil filter fittings, tin wear, bearings, seals and misk bits also.
It does require assembly, no heads.
He’s looking for roughly $2,000.
PM me for his number
