I have 2 notches, a 65 manual and a 72 auto. my daughter loves the early shape but can only drive autos. is it possible to straight swap the motor/boxes, if not, what would be involved, and has anyone tried. don
newghia ·
Swap the body onto the auto pan....
That's what we did with my razor...type 34 ghia
donovan ·
that sounds too sensible and too easy. there must be a catch
mackaymanx ·
Yes the vehicle will then be a '72 and have to comply to ADRs for that year, the '65 body may not meet the requirments.
newghia ·
That is true, it would then be known as the year of the pan, check with your relevant government dept (DMV ) or speak to an engineering signatory .... Would not imagine there being too much issue, a few things come to mind though....bumper bars & collapsible steering column......which you could use from the donor car.
split ·
drop the swing axle sub frame and put in the irs rear end from the 72
may as well do the discs too
mackaymanx ·
You would also need to graft in the surround about the shifter and rear engine mounts.
newghia ·
Full Pan & running gear swap would probably be easier & quicker
mackaymanx ·
Still need to fabricate rear engine mounts.
donovan ·
found an easy solution. told her to get her manual licence, then she can drive either. now shes not talking to me. problem solved
