Aussieveedubbers 路 Tech Talk
Using Diesel as an Engine Oil
https://forums.aussieveedubbers.com/threads/110326/using-diesel-as-an-engine-oil
Blue65 路
I was talking to another customer in an autoshop - and he told me he used diesel as a temporary engine oil so that it could help clean his engine.
His car was a Ford.
It seems an extraordinary thing to do. I wonder whether anyone in this forum has tried it?
adlbeetle66 路
Who cares if its a ford 馃槀馃槀
karmann141 路
adlbeetle66 wrote:Who cares if its a ford 馃槀馃槀
Hey didn't you have a Turbo Ford Territory ?
h 路
Good idea 馃憤
bugzla 路
heaps of detergent in there
grazza7755 路
Perhaps he meant using diesel oil.
I know of people who do that to clean their engines.
landfall 路
Diesel is oil.
You could also use heating oil.
1303Steve 路
I've heard of it, wouldn't drive the car anywhere, its supposed to free up stuck lifters which a VW engine doesn't have
adlbeetle66 路
Shhhhhhhhhh..... 馃槑
TasDub 路
I did it once to a red motor in a HR Holden. The purpose of the exercise was only to flush the inside of the motor. We used a mix [ half and half] of diesel and the normal oil and let the motor idle for a few minutes keeping an eye on the oil light and the temp gauge. After the few minutes we dropped the mixture out and fitted a new filter, repeating the process. After two flushes we fitted another new filter and a proper amount of fresh oil. From memory there were no ill effects afterwards........................cheers............Wayne
Blue65 路
Is it diesel engine oil that you used or diesel fuel?
REDKG 路
As stated, diesel fuel is used to flush out the oil system. You don't drive or put load on the engine under this condition. I recall many years ago
a car had been stored at a house I was renting for over 2 years. The NRMA breakdown guy couldn't get it to start (hard to turnover) and he resorted to putting a butane stove under the sump.He then drained what oil would come out and refilled with diesel fuel. He was then able to get it to turn easier and start. After a while he drained the oil mix and refilled with straight oil.
nsuwift 路
I read and have done this with transmission fluid too for the same effect.
