Ok dubbers can anybody show me a picture of where the lower seat belt bolt go on a 67 bug please, I have the top holes and the holes for the ones on the tunnel in the middle dut no lower ones????
Thanks all sloth
there was no mount hole for the lower end
most use 2 plates top and inside sandwiched through the floor pan
clyve ·
Not quiet sure what you mean can you enlighten an old idiot pls cheers
there is NO lower hole for mounting a 3 point safety belt
most people get 2 pieces of steel plate then drill a hole in the floor using one plate on under side and one on the top to secure the belt at the 3rd point
Governor ·
What he means is they only came with a sash belt and not a lap and sash.
The belt only went from your shoulder to the gesrbox tunnel and not back again over your lap
Most people buy the lap and sash belts and drill another hole in the floorpan by the side of the seat near to the door and use a plate to spread the load ondernesth the floor when they bolt the belt to it.... If that makes sense?
clyve ·
Thanks guys
You can purchase a set of plates one with a captive nut on it
