REDKG ·
An early 1200cc engine with one head with long studs and the other modified to short studs. Would It be correct to adjust the short stud one 0.006 and the long stud one to 0.008/0.012 ?
https://forums.aussieveedubbers.com/threads/110398/long-stud-valve-clearance
REDKG ·
REDKG ·
1500S ·
Why not modify the long stud side to short stud. It is done with the engine still in car. Maybe Vintage has the modified studs for you. Early days the hole where the long stud went was tapped 9/16" UNF for the then available short studs but these days M14 x 1.25 would be the go if getting them made. Can you get a couple made if unavailable?REDKG wrote:An early 1200cc engine with one head with long studs and the other modified to short studs. Would It be correct to adjust the short stud one 0.006 and the long stud one to 0.008/0.012 ?
REDKG ·
