Occasional noise after replacing starter
https://forums.aussieveedubbers.com/threads/110425/occasional-noise-after-replacing-starter
hulbyw ·
Replaced the starter in my '68 Type1 with a recoed unit. All well except after a week, the starter is making a horrible noise sometimes when starting. Sounds like the starter gear is clashing with the flywheel. On reading the Bentley manual, the only thing I didn't do was greasing the starter shaft bushing. Before I pull the starter and grease the bush, is there anything else I should be doing?
Cheers.........Wayne
Could be a different flywheel
HappyDaze ·
Looks like you did everything the right way, i.e., read the manual AFTER you've done the job. 😏
hulbyw ·
HappyDaze wrote:Looks like you did everything the right way, i.e., read the manual AFTER you've done the job. 😏
Hah! I read the idiot manual to do the job and it didn't mention greasing the bush😢🤪
