Hi Guys, just looking for a little help if possible.
I removed the speedo from 1963 Kombi to see if i could get the mileage tripmeter to work. Anyway, tried to place it back in vehicle with wires the same as I removed them (but not sure!) but now the blinker lights flash when you start the bus. The actual blinkers do not go, unless you use the indicator stalk. At a loss. It has a 2 pin flasher unit with one of the pins piggy backed. There is a large white wire attached to the top of the speedo near the blinker bulb but i think that was where it was originally.
Alfonso56 ·
