Wiring looms available
https://forums.aussieveedubbers.com/threads/110459/wiring-looms-available
ratbug ·
Hey guys, Just looking at my collection of wiring looms I have obtained and converted over the years, I offer these for basically the same price to get them converted using your exisiting loom. Some are loom only, some have the ECU and other parts.
EJ22 Loom only from Gen1 Liberty (4 yellow plug ecu, two big plugs engine + sepeate cam and crank plugs) $350
EJ20T Loom plus ECU. From a 94 RS Legacy. This was what I had in my green sharpbuilt before I put the 2002 VVT heads on it. Can also be used for early model WRX engines pre 98. $400
EJ25 Loom plus ECU + Immobiliser parts from 00 Legacy/Liberty (single cam) $450
EJ25 Loom plus ECU + Immobiliser parts from 03 Forester (single cam) $400
EJ20 Loom plus ECU + Immobiliser parts + Drive by wire throttle + dash cluster from 08 Impreza Quad cam canbus) $600 (not needs Canbus emulator)
Also have a few accessiories to suit the above, such as instrument clusters, fuel pumps, radaitor fans etc and can add these with the looms if needed.
Not sure if this needs to be in the for sale section, but thought it is more appropriate in the engine conversion section.
PM me, or 0427 337758
bugzla ·
do you have any for a 2004 impreza ej25
