Whats a good exhaust / muffler system to get?
I have a 1641cc engine.
I saw this -
http://shop.vintagespeed.com.tw/s.nl/it.A/id.523/.f
Blue65 ·
https://forums.aussieveedubbers.com/threads/110472/best-exhaust-muffler-system
Blue65 ·
lauzboy ·
psimitar ·
Blue65 ·
Thanks you.psimitar wrote:If the engine is basically stock, bar the extra few CC, then the Vintage Speed is the nicest solution and won't ever rust like the large majority of header and silencer options on the market.
Check out their website as they're only in Taiwan, IIRC, so direct shipping could save you a few pennies. Worth a shot 🙂
psimitar ·
Yup, tis just a .com.tw address. Here it is Vintage Speed Taiwan websiteBlue65 wrote:Thanks you.
Do you have a link for that please?
ragged ·
psimitar ·
Blue65 ·
Sorry is the vintage speed one have the Abarth style??psimitar wrote:Well the Vintage Speed is meant to flow better than the std exhaust so will make a few extra ponies but should make it rev more freely too.
I do vaguely remember Volksworld doing a back to back test on a std 1600 with all the types of aftermarket exhausts compared to the standard and the vintage did give more BHP yet the Abarth style was worse than the stock exhaust as well as the phat boy muffler cos it dropped exhaust gas speed too much for the 1600 but would work better on a 1776 upwards.
Bigger tips would help reduce back pressure but if the Vintage internal tubing of the main can flow better than a stock exhaust then it'll always be better and would still work well upto around a 1776. Then I'd say it would start restricting the flow of larger motors 🙂
Blue65 ·
Can you buy them here or did you order them from Taiwan direct?lauzboy wrote:I've had several exhausts, the last one being a stainless extractors and hide-away system. I ditched it and got a Vintage Speed and wish I'd done it sooner. I've been running the VS system for about 5 years and wouldn't go back.
Whilst the extractors probably flow better, the VS system doesn't bottom out over driveways, fits the stock rear apron cutouts nicely, you don't have to take the muffler off to do #1&2 tappets, etc
The build quality justifies the price, and if you're running a single carb then the pre-heat tube outlets actually flow the exhaust gas THRU, not just pulsing from #2&4
Blue65 ·
Yes, I'm interested. I have a 1641cc engine with heater components - will it fit?ragged wrote:I have that model with the heat risers brand new that you can have for $750 delivered, if your interested? Dave
ragged ·
psimitar ·
No mate. I was just elaborating on the different types of exhaust that were tested and used the Abarth as it's a popular-ish choice due to the twin tip outlets making it look like an old 60's Ferrari style exhaust. However looks doesn't mean it'll actually perform.Blue65 wrote:Sorry is the vintage speed one have the Abarth style??psimitar wrote:Well the Vintage Speed is meant to flow better than the std exhaust so will make a few extra ponies but should make it rev more freely too.
Blue65 ·
Cool. What's the warranty like on this? Do you run a shop or are you affiliated to Aircooled?ragged wrote:This is the muffler. http://vwparts.aircooled.net/Vintage-Speed-SS-Sport-Muffler-155-203-05200-p/155-203-05200.htm
You can use these to fit standard heater boxes. http://vwparts.aircooled.net/SearchResults.asp?Search=155-200-FF100
