WTB used piston(s) and cylinder(s)
https://forums.aussieveedubbers.com/threads/110479/wtb-used-pistons-and-cylinders
BennVenn ·
Im looking for one or more piston+cylinders for a hit n miss project. Prefer 1200 but anything will do! Txt 0421000530 or bennvenn@hotmail.com
Thanks!
applez ·
I've just pulled apart a 1600 motor with no use for old cylinders, pistons or heads. PM sent.
Tell us all WHAT your trying to achieve and it may make it easier to help you out
thers a big difference between 1600 and 1200 pistons sizes
BennVenn ·
Well, as the original post says I'm looking for one or more piston and cylinders for a vintage hit'n'miss engine I'm building.
I don't believe there is a huge difference between a 1200 and 1600 cylinder other than bore size. It'll be an open crank design with vacuum intake valve and cam driven exhaust valve. I have an aluminium foundry for the castings and a 3d printer for the molds and core boxes. I cant pour cast iron so im looking to re purpose a vw cylinder.
Ill be designing as I go so any sized cylinder will do. I've already got the cam gears and lobes (only parts i cant make) and I've started on cylinder head design. Once I get hold of the cylinder and piston I can start welding the crank and work on the push rods, rockers and cam follower.
My wife doesnt like me hoarding or else I'd have a set of 1300's that came off the bug the last rebuild :-(
While on topic of casting, I have a few sets of injected manifolds I've casted for a twinport. Perhaps a swap? Oh and if anyone needs custom cast parts im happy to help you out!
HappyDaze ·
Now there's one to make a note of..."custom cast parts". 👍
I've got plenty of cylinders & pistions you can have, Benn. Where are you ? DO WE REALLY NEED ANOTHER ONE OF THOSE HIT'N'MISS ENGINES, THOUGH ? 😂
Well Benn that sounds really interesting
Where are you located I know of a few people that can add to your project
BennVenn ·
I'm in a little town called windellama, it's 60min from Canberra, 30min from Goulburn. I work in canberra.
I want to build the hit n miss to get all my tooling sorted for the tricky stuff, line boring, cutting valve seats etc then start a build on a 1915 cyclone motorcycle engine.
Where are you HappyDaze?
HappyDaze ·
Not far away...Burradoo [between Moss Vale & Bowral]. May have other stuff of some use 👍
Send an email, if you like... greg at kirrapak dot com
