Hey guys,
last year, we swapped a Subaru EJ25 SOHC engine from a 2000 Legacy (156 hp) into our 1973 superbeetle.
However, the ECU constantly reports error code 38 "Engine torque control" or "Torque permission signal". When I checked the ECU with OBD2, I found values for "Engine Torque Request", "Torque permission signal" and some more stuff that leads to the conclusion that the ECU is expecting to have a Subaru automatic transmission with the corresponding TCU connected.
I bought another ECU that was confirmed to be out of a car with manual transmission, but after installing it, I got exactly the same behavior and the same error codes as before.
So there are two options:
1. Someone screwed me over and the new ECU is again out of car with automatic transmission
2. The ECUs are actually the same for AT and MT and the transmission mode is set somewhere else...
For the older engines 1996-1999, I found some information about a AT/MT identification pin on the wiring harness, which defines whether the ECU should behave like AT or MT.
Does anybody know, where to find that pin on my ECU (2000 Legacy, EJ25 SOHC 156hp) or if it even exists?
I checked multiple websites for ecu pin-outs or wiring information, including this one:
https://hackedecu.com/ultimate_subaru_pinout
But I did not really find anything useful for the 2000 Legacy...
best,
Chris
Chr_ ·
