Battery cover ????
https://forums.aussieveedubbers.com/threads/110689/battery-cover
bugmaniaar ·
Hi all.
We have a 63 beetle that has been converted to 12volt.
Should there be a cover over the battery to stop it shorting on the seat bottom?
If so what does it look like? any pics?? heading for a road worthy soon...
Thanks all..
barls ·
mine is a piece of thick carpet.
bugmaniaar ·
Like the idea of carpet or something,but not too sure about passing a road worthy...
AA003 ·
The best way would be to buy a recessed terminal battery like later VWs have or get a cover from a 1500 Beetle.
karmann141 ·
Agree with above, but if you don't need a new battery -
Pictures of correct covers, but a rubber car mat works just as well.
https://www.classicveedub.com.au/cvd_new/parts.aspx?SearchData=battery
get the later type battery with sunken terminals and a rib on bottom to lock it in place you will need the clamp bracket as well
I have had mine in 65 bug for over 12 years no problems
adlbeetle66 ·
Yep. I'm using a super cheep clamp on a rubber mat and its doing fine.
If he's really worried, maybe a piece of ply wood may work, or just a late beetle cover.
Blue65 ·
I use a thick rubber mat to cover it - something which is not flammable and can prevent the battery from shorting on the back seat metal frame.
bugmaniaar ·
Thanks for the info.........
