Aussieveedubbers · Busses
Windscreen wipers is there 2 different sides
https://forums.aussieveedubbers.com/threads/110722/windscreen-wipers-is-there-2-different-sides
Glen75 ·
Initially my wipers were on the drivers side of the jets, but since the new nose has been fitted, they are now on the passenger side- this obviously moves the whole motor assy over and now it fouls on the air intake box. Can i buy a different wiper assy to work on the 'other' side as such?
gday mate
what model car and what do you mean by "but since the new nose has been fitted"
ok - so its the low light kombi?
you have had a late bay nose put on modified to be a low light
so - yes, im guessing there will need to be some mods
ragged ·
Perhaps the new nose was for a Left Hand Drive vehicle?
Dave
i think maybe the panel beater welded up the wrong hole?
Glen75 ·
Bizarre wrote:i think maybe the panel beater welded up the wrong hole?
Unfortunately it is looking that way!! To redrill and fill the other hole now is a major pain in the butt- id rather go with the 'other' style mechanism if avail- i have seen on a couple of other kombi's the holes on the same side that mine are now.
Ie these 2
[img]https://farm2.staticflickr.com/1540/25802252052_e252e79579.jpg[/img]C2271EDC-585F-4B01-ADE2-EC230F410933_zpshjsg3ecp by ghordern, on Flickr
[img]https://farm2.staticflickr.com/1593/25828106771_852c050855.jpg[/img]Aug27 2015 11_zpshmlppzzn by ghordern, on Flickr
Cant drill and rubber grommet the other holes?
grumble ·
There is a left hand park and a right hand park mechanism,from memory they changed to meet the RTA standards for blind spots in the drivers vision area.
AA003 ·
grumble wrote:There is a left hand park and a right hand park mechanism,from memory they changed to meet the RTA standards for blind spots in the drivers vision area.
It's an Australia only thing.
Scottkombi ·
Early bays as shown in many photos above were basically designed for LHD vehicles and wipers were not altered for RHD vehicles until around 74.
Hence if you have a late bay you probably bought a Brazilian bay front panel as they are cheap and readily available still and these are design for LHD vehicles so the wiper holes will be on the wrong side. You need to either drill new holes and weld up the old ones or get the plug grommets OR you but an early bay wiper mechanism and wipers. Note the early bay wipers are angled specifically for LHD vehicles so your old wipers wont work.
A few decisions to make there.
Kombi7 ·
Mmmm....yes, the wiper assemblies. If you go to VW shows or see a collection of Kombis in the one place you will notice the wipers are random. Many Kombis had front panels that would accept either hand, the unused one simply had a rubber grommets to fill the extra holes. Our Kombis are a mixture of LH and RH park, the ones where we had to replace the fronts are RH park (for LHD vehicle) but two are still original fronts and one is LH the other RH park (78 & 79 models).
My advice, source the correct unit for your nice new front, trying to fit the opposite ends in tears.
