OK, just rebuilt motor with an Engle 110, new lifters, hd springs.
Will not start, got sparks, fuel and compression. (ran fine on stock cam)
Checked timing many times, No1 both valves closed on TDC, rotor pointing to No1
Correct firing order, no explosions at all. Even swinging the dissy left or right.
Swapped wires over a few times, still nothing.
Started looking at cam opening times.... All from TDC No1 rotating engine clockwise.
No1 intake starts to open at 450 degrees (full rev plus 90)
Stays open for 270 degrees (back to TDC)
No1 exhaust starts to open at 200 degrees.
Stays open for 310 degrees.
Seems horribly wrong, am I measuring correctly?
During assembly I set the cam in the correct position, sure it did not move.
What stupid mistake have I made?
Dave
roofchop ·
