WTB 12 volt starter
https://forums.aussieveedubbers.com/threads/110825/wtb-12-volt-starter
gazzac ·
Hello all. I am after a 12v starter for my 66 beetle. I am running the original transaxle that used to be a 6v. Would prefer South Australia as i know these things are heavy to post. Regards Gary
adlbeetle66 ·
Can't help with the Starter at the moment, but i know that you'll need the little bush that goes in the gearbox.
Its a little brass cylinder that converts the 12v starter to the 6v gearbox, available for about $10-20
gazzac ·
Thanks for the heads up adlbeetle66.
torana ·
will see what i have in my box of bits tomorrow. hopefully they are marked 12V. 🙂
bushed ·
what flywheel (not transaxle!! are you running? 12 volt as the teeth are different to 6v
6 volts turn great in a 12 volt car as you use them very little
I have 2 6 volters tested $80 plus post IF u hve a 6 volt flywheel on as on your orig engine ala 66 bug
