I am having a clean up and am trying to get all of the used parts out of here as they are taking up too much space. This will be the first of about 20 engine kits that I am putting together that are all complete and ready to assemble.
I am just too busy to assemble these so please do not ask as they are all going to be sold as kits, all machining has been done to make the assembly process easy for you. This kit contains the following components that are all used or otherwise specified. This engine will suit a beetle or buggy and will be ideal for someone with basic knowledge of engine assembly,
Brazilian case with fresh line bore @ .060, light thrust cut on the rear main, opened for 90.5mm bore cut for front seal, full flowed
New KS main bearings cut to suit case
Std crank checked OK-std/std
Std 12 volt Flywheel
New Cro-moly gland nut/washer
Std conrods checked OK
New Silverline rod bearings
Engle W100 camshaft with Aluminium gear
Matching lifters for cam all marked for re-assembly
Std OEM aluminium pushrods
New Silverline dual thrust cam bearings
Cylinder deflector tins
Complete crank gear kit to be installed
New Steel cam plug
Dizzy drive/spring and shims
All nuts/bolts/bearing dowels/dipstick
New 90.5mm piston/barrel kit
New Stainless pushrod tubes
New Gasket kit
New Rear main seal
Std VW rockers
Std VW valve covers
Degree pulley with seal
Reco'd std heads with light porting opened for 90.5mm
26mm Oil pump, o'ringed with full flow cover
This is basically a complete kit for you to assemble and everything is included from the front pulley to flywheel and valve cover to valve cover. I am more than happy to help you out along the way if you need some advice and I am located in Wollongong NSW and this kit is priced @ $ 2400, 02-42729920. www.rodpenroseracing.com.au
RodPenrose ·
