Fastback and Slow Ghia
https://forums.aussieveedubbers.com/threads/110855/fastback-and-slow-ghia
Paul Cave ·
I've been working on a Ghia for more weeks than I care to remember - on and off. Finally got the safety certificate yesterday. Happy days...
Also took the grinder to the Fastback. Not so happy days.
Paul Cave ·
Fastback - trial fit of engine into late model Type 3 rear suspension subframe (it's times like these that I wish I had frame horns)
Paul Cave ·
Then a quick dismantle...
Paul Cave ·
Needs pans and a heater channel. I'll patch the pans (probably). Not going over budget on this one. Anyone got a passenger channel before I start to patch that too? Bottom and inner rotted away, outer's not too great either. Only top part looks solid.
Paul Cave ·
FB channel - passenger's side - top part is best side! Not much inside, not much outside, and even less underneath.
volksmanharry ·
Hi Paul
I've got a good pass Heater channel cut also some other cuts from a 68 notch I wrecked you might be interested in. Also a whole floor pan: http://forums.aussieveedubbers.com/viewtopic.php?tid=110553
In Toowoomba though.
Cheers Dave
Paul Cave ·
I've sent you a PM Dave. Brother lives in Toowoomba. 🙂
walter64 ·
Keep up the good work, thank goodness you have such a big undercover area to work.
Paul Cave ·
walter64 wrote:Keep up the good work, thank goodness you have such a big undercover area to work.
Paul Cave ·
Update - Little Ghia motor (original 1200 fitted to the car at birth) has been breathing real hard up these hills. I decided to save it from further abuse and for flatter terrain in the future. This weekend I pulled a '67 1300 out and installed it into the Ghia. Anyone contemplating such an engine change? Well I can vouch for the torque improvements. It makes driving much more pleasant in hilly terrain. It's still slow, but less "sweaty". I haven't tested the full 6 extra bhp yet. Woohoo! Hopefully the Ghia will still return 40mpg on a long run over to Toowoomba. 93cc extra goes a long, long way! 😎
walter64 ·
Paul, you've gotta do better than 1300
