IDF40's centre mount air filter
https://forums.aussieveedubbers.com/threads/111106/idf40s-centre-mount-air-filter
landfall ·
I am considering making a centre air filter set up for my dual 40's.
The engine is 1600 capacity and I am running 28 vents.
It appears that there is a lot of turbo induction material about and it would be easy to make a system from 3" dia pipe work.
I have a feeling that with 3"pipe work I may have air velocity trouble?
Is there a maximum size I should be looking at or will 3" intake tubing be OK?
I would think that the 3" would be ample
I used CB Turbo Tops and they are 2"
Have a look at the CSP one
vwo60 ·
I made this et up on a 1775 with a engle100 cam, the pipe size was 2.5 inch, an over kill really when you consider the standard air clearer inlet size, this worked very well and made a good improvement
landfall ·
Thanks for the photos, I have started to fabricate a 3" system.
CH5353 ·
Have a look at Alfa boxer style engine set up.
Fan housing maybe a problem but could give you some ideas
They fit with some mods to T4 in a 914
lauzboy ·
here's what i made out of PVC pipe as a proof of concept. Works a treat at quietening it all down. I might eventually get around to getting it fabricated in steel or ali pipe
barls ·
this is the one that we made ages ago its based on an excel airbox.
landfall ·
Thanks, that givers me plenty to work with.
