Hi,
I'm getting rust sediment in the carb bowls even after cleaning them out two days ago, it's had the tank treated so I know it's not that, their is a tube filter in the tank which wouldn't stop the small stuff.
A large metal filter prior to the pump and it's going through that into the bowls,
I fitted a small plastic filter from the pump to the carbs yesterday. only started the motor to see if any leaks.
I am assuming that the metal fuel line up through tunnel is rusted, so I think I will replace it.
Has anyone done this because I think it will be a little difficult.
I spoke to Mick motors and they suggested running it along the tunnel on the passenger side with holes drilled with grommets each end.
Any suggestions
Thanks.
paslow22 ·
