Hi,
Have You checked the Hi riser heater pipe underneath the inlet manifold.
I have had a couple of them rust out which lets the manifold get very COLD if the outside temp is coolish.. it also allows the exhaust to leak...
Air Cooled VW engines don't like any leaks in the exhaust or inlet manifolds etc...
it looks like it maybe a cracked head...
I presume You have used a timing light on it...
I don't like 009's especially if they aren't genuine..
I don't believe using 98 octane should cause problems, E91 or E95 I wouldn't use.. [ethanol]
Did You use anti-seize or similar on the spark plugs??
I do on ALL alloy heads...
I did have a bad spark plug a couple of years ago... it tested Ok initially and it did go a few hundred KLMs before it started to play up.. the engine idled and drove Ok except on the highway/expressways etc over 90KMH.. it was like half spark on & off... but the engine didn't misfire etc..
Best of Luck
hulbyw wrote:I have a beetle with a quite worn 1641 and standard carb. It has a 009 with Compufire, I made the mistake of giving it some love, such as filling it with BP ultimate, adjusting the valves and replacing the plugs and ever since it is misfiring under load. Starts ok but when revved or under load pops and farts.
To date I have changed the plugs again and new copper ignition leads. This fixed it for a day then it went back to worse popping and farting.
I have now put in a new rotor and dissie cap, new fuel filter and removed the carb and cleaned it and blew out the jets and orifices with compressed air.
It now goes a bit better but still popping and farting under load. Any suggestions to fix it would be really welcome
Cheers.......Wayne
