Hi all, just a quick question. I'm doing a quick rebuild on my type 3 notch, 1600 engine. I have bought another 1600 upright engine that was in a kombi with a cracked case as it had an engle cam in it, which I intend to use. Putting the two cases next to each other, the upright has larger diameter barrel/head studs fitted.
Would these have been fitted as an upgrade or is there some diffenence that larger studs are in place? Also is it worth fitting the larger studs to the case I'm going to use? The old engine was leaking oil pretty badly and all gummed up hence giving it a tidy up and replacing the pistons barrels, but it was running without any major issues.
Thanks in advance. Adam
adams kombi ·
