Hi all probably covered many times, I've wd40 the hinges hammered with a Phillips screw driver, I will heat after they come off .
But I'm looking to borrow or buy one of those hammer ratchets to get the screws loose? Any suggestions ?
Or other ways?
Cheers Brendon
HappyDaze 路
Pity you lost my phone #. 馃槒
Kroozzn61 路
And maybe I can find it!
Mr Mackie
Kroozzn61 路
What about my makita hammer drill?
HappyDaze 路
PM sent. 馃槒
psimitar 路
Yea, an air ratchet gun normally does the trick so an impact driver in reverse should work too. The hand held impact driver that you twat with a lump hammer needs to be a good quality one cos the Supershite ones may loosen a hinge before being a paperweight 馃檪
adlbeetle66 路
I've got the vice grips on the screwdriver, and turned it while bashing the end of the screw driver - got a few out - the rest i drilled and used an 'Easy-Out'
Kroozzn61 路
borrowed this, what a beautiful tool..
Doors off..
psimitar 路
Good job 馃檪 One of those impact screwdrivers sure work well if not a Supershite cheapo 馃檪
