Help. Has anyone got a M11 x 2.0 tap for seatbelt bolt threads?
https://forums.aussieveedubbers.com/threads/111414/help-has-anyone-got-a-m11-x-20-tap-for-seatbelt-bolt-threads
fullnoise ·
About a 17 years ago I had anchor points welded into the C pillars of the oval. Now I've finally removed the roll bar and I'm putting seatbelt a in the back.
It was really tricky to get the bolt to find its threads in the drivers side bolt. It took about half an hour. The passenger side has been even more tricky. All I need is a tap to clean up the thread.
But despite the millions of cars driving around Aus wth these bolts nobody seems to have a tap for this unusual thread.
I can get one custom-made by Suttons tools in England which will take 9 weeks and cost $200. So I can use it once!
So does anyone have one I can borrow or rent and return?
I don't want to drill the bolt out to an M12 as it may cause safety issues for the cars future custodians.
CT
mackaymanx ·
Standard seatbelt anchors in Australia are 7/16" UNF 20 T.P.I (11.11 mm x 1.27 pitch). Are you sure that you haven't got that size. If you had it done around 2000 then it would have been done to the Australia Standard (ADR) of 7/16 UNF.
Camo ·
Hi CT,
Cant help you with one for a loan but found one here in Australia for $62 if you get desperate
https://www.bolt.com.au/m11-20-intermediate-high-speed-steel-tap-p-100034.html
Kev
AA003 ·
I think that I would prefer to use the correct tap.
HappyDaze ·
You should use 7/16 UNF high tensile bolts, or else increase your public liability insurance, CT.
hellbugged ·
I'll look for that size in the cupboard tomorrow CT
fullnoise ·
Thanks for your help everyone.
I think Mackaymax is right. Thanks 🙂.
The tool shop I took the bolt to sent me down the wrong path by accident. It seems so much more logical that it's a common 7/16 UNF thread when you consider how common seatbelt bolts are. I bought a 7/16 tap yesterday and I'll try it in the harness plates first.
CYA CT
AA003 ·
If you did get a M11x2 tap, where would you get the bolts from anyway?🙂
nbturbo ·
Ol HappyDaze on the money again
yeah 7/16 UNF thread I have tap and spare bolts CT if you need
hellbugged ·
7/16 unf yep
Got it,...
.....read the updated post....
.......put it back.....
......Jeff swore at you
psimitar ·
7/16 is almost exactly 11mm and as far as I know the 7/16 seat belt bolt size has been an worldwide standard since the 70's.
fullnoise ·
Yup 7/16 UNF. It was a bugger of a thread to fix. In fact it felt like I was taping an entirely new one. But it's good now.
Thanks everyone.
