71dub wrote:Hi guys have fitted a new speedo to my 1971 vw beetle everything is working except the gen light and oil light . both were working on the old speedo be fore the change also when car started the indicator light glows dimly all the time .i have checked and don't seem to have any wires that i have missed .pictures of speedo attached any help would be greatfull
The wire right at the bottom is live when the ignition is turned On...
pull the terminal on & off a few times to clean the terminals...
The Oil light earths out from the oil pressure sender on the engine...
[the oil sender is the small sender] You may need a new oil sender,,
If You have an alternator, the light Must go ON with the ignition.. and then off after You start the engine..... [alternator charging]
Do You have a generator or an Alternator...???
That is an alternator on My engine...
Generator's are smaller in diameter...
Oil sender is below the distributor...
if You take the wire off the oil sender and earth it to the engine - bare metal.. with the ignition turned ON.. the oil light should go on...
means You need a new oil sender...
