even more parts added
https://forums.aussieveedubbers.com/threads/111485/even-more-parts-added
binner ·
ok, so time to off load..... more added , see last post for new stuff added
single port heads only
Bris 4012
0404874097
Price pairs $40
pick up preferred but can post...
> from left to right of image, numbers represent one head only, so if you want to buy only one head, give me only that number, if you want several give me all numbers you want. I tried to pair them up, all good and useable, no cracks or broken fins. If you want them sand blasted its an extra $25 per head.
cheers,
Ian
binner ·
following on.......
Item: Single port heads and heaters
Item Condition: used
Reason for selling: surplus
Price and price conditions: $125.... now 85 bucks
Extra Info: all goood, no cracks , broken fins, heaters look ok to use
Pictures:yup
bushed ·
lettuce know the cost of the veg...lol
no tp aye?
binner ·
^^^^yup, i have a few twin ports, just need to post them up.....
got some bug gearboxes too.....
heaps of rockers
valve covers
pulleys
fan shrouds
AS 41 cases
set of reduction boxes
generators
oil pumps
axle shafts
wombatventures ·
After an irs box to fit our Super Ian.
Any in your stash?
sander288 ·
what are the fan shrouds? 36hp or later?
binner ·
wombatventures wrote:After an irs box to fit our Super Ian.
Any in your stash?
Is this the one?
All gears engage, sounds nice but I would be dumping oil and refreshing....
binner ·
sander288 wrote:what are the fan shrouds? 36hp or later?
I only have these.....
2nd,3rd image is the same shroud
binner ·
more bits,
reduction boxes
2 inch body lift frame for baja build SOLD
stnd 3 rivet type 1 cams
several oil pumps
IRS gearbox type 3 1600
adlbeetle66 ·
Any 12v bell housings? (as in removed / cut from gearbox)
I want to use it to start engines on the ground
binner ·
adlbeetle66 wrote:Any 12v bell housings? (as in removed / cut from gearbox)
yep, a few
More stuff....
binner ·
lift kit is sold.
tayloredvw ·
any l-bug gearboxes?
waltermitty ·
how much the three rib ?
bushed ·
am after a 2L starter Binni
B
binner ·
tayloredvw wrote:any l-bug gearboxes?
thats a naddah sorry.....
binner ·
waltermitty wrote:how much the three rib ?
decieded to keep that one for my buggy build,
sorry....
binner ·
bushed wrote:am after a 2L starter Binni
B
I'll check in the morning fellah....
binner ·
AS41 VW 1600 case in really good condition. Comes with a 69 mm crank, standard pushrods,lifters,oil pump, pulley, oil pump cover, sump plate, standard cam and standard VW rods.... All in good condition.....
Bris 4012
$550 for the lot or best offer.
I also have 3 standard 69mm cranks in good cold..... $150 each ono
bushed ·
B
binner ·
B
found one for you squire....
binner ·
more added, not using these now either
kombi gearbox $400
beetle box with a 4.125 gear installed $250
