KalgoorlieGreg wrote:Hi all,
Was wondering, here in Kal, it gets over 40C constantly during summer and would an extended sump help to control engine temps? More oil would help disperse heat better?
I could be totally wrong and happy to be schooled!
It doesn't make much difference to the oil temperature when the air temperature is 40c..
Greg with a beetle, I recommend having the top of the engine lid open using either the readily available alloy hinge STAND OFFS or I use the steel bracket that is made from welded flat steel and can be installed or taken off in less than a minute..... so the top of your engine lid is open about 75mms approx.. and this does make the engine run cooler in the summer at 40c... with the air coming over the roof and into the engine bay... I have vents in My engine lid so the hot air can also get out....
You will also see many early engine lids with two sets of vents in them, which was original in early beetle cabriolets, but all those You see will have been made up. Now if Your engine is still a single port with original fan and housing, You can change to a later wider fan and housing plus the wider [larger] oil cooler which will help keep Your engine much cooler than the originals. Do You have any pics of your engine?
My 1968 model beetle had no vents in the engine lid, but later ones did, and also was a single port engine [still is] but now has the later fan shroud with new wider oil cooler and wider fan etc.. called a dog house fan shroud as the oil cooler sticks out from the back of the housing...
Make sure that the very hot air coming out under the engine cannot get back into the engine bay and getting sucked into the already hot oil cooler
The rubber seal around the engine bay needs to be in good condition.
