WTB: Early Type 3 Rear Brakes Assemblies
https://forums.aussieveedubbers.com/threads/111553/wtb-early-type-3-rear-brakes-assemblies
adlbeetle66 ·
As title states:
I'm chasing a pair of early (wide 5) type 3 rear drum brake assemblies.
I'm in the process of changing gearboxes on my beetle and want to upgrade the brakes at the same time..
Contact Denver: o447o55o35
The closer to Brisbane, QLD the better!
bushed ·
what bx u putting in?
how would Superbug brakes go? cheap
any news re other parts?
adlbeetle66 ·
I'm putting a later swing axle in it for the 12v bell housing and better gear ratios.
No, i need type 3 brakes for the wider drums and wider shoes.
I'll send you an email
bushed ·
Superbug brakes seem big ...tis what I have....research needed..
adlbeetle66 ·
Yes, but i want the wide 5 stud pattern.🙄
ovalkeith ·
Hey Denver, not a cheap option but by the time you've found some Type3 brakes, bought the little bits and pieces to fit them, the cost might not be too far out.
Check out these CSP drums
I have a set of CSP drums on the back of my split
adlbeetle66 ·
Thanks for the thought Keith,
Ill keep it in mind.
adlbeetle66 ·
Bump
REDKG ·
Good conversion. Are you using short or long axles ? If using short you will need to machine the centre boss about 10 mm. I may have sets of machined and non machined, will check over the weekend. Bit heavy to ship from Sydney though.
the hard part will be finding the brakes very hard to find now days
adlbeetle66 ·
REDKG wrote:Good conversion. Are you using short or long axles ? If using short you will need to machine the centre boss about 10 mm. I may have sets of machined and non machined, will check over the weekend. Bit heavy to ship from Sydney though.
I'm using the earlier axles... Happy to pay for shipping otherwise have family in Penrith that can pick up...?
Looking forward to your reply...
Denver
0447055035
adlbeetle66 ·
Bump. Never head back from you REDKG?
