Longer frame horn bolts
https://forums.aussieveedubbers.com/threads/111563/longer-frame-horn-bolts
vduboy ·
Does anyone know where you can get the longer frame horn/transmission mount bolts from? I have seen them somewhere but cannot remember where.. I need to mount the Subarugear mount on top of the Manxter's cage rear brace thingy.. Thanks!
psimitar ·
I've never heard of longer ones for there. The bolts are long enough so the bolt on 3 point kafer bars don't present a problem but s'pose more than this would.
I'd take one to a bolt supplier and see if they can help. I wouldn't be surprised if it was classed as an ultra fine thread due to the bolts diameter.
nbturbo ·
They are 18x1.5
vduboy ·
Cheers guys, yeah I found the thread size and length on the samba, also found some high tensile bolts that are longer but have no step, so I will machine some collars up and tig them on if I can't buy any with shoulders.
HappyDaze ·
Welding not a good idea...make the collars a shrink-fit on the bolts, or Loctite them on.
