Widening steels guards
https://forums.aussieveedubbers.com/threads/111582/widening-steels-guards
RAW069 ·
Hi all
I'm looking to widen my rear guards to match fit the 9 inch Porsche Twists that I recently bought.
I want to do this with the existing steel guards, and was thinking of using a second set of guards to gain the same profile and also have only the one weld, rather than welding in a strip.
This would be achieved ( in theory ) by cutting the doner guard leaving a strip on the inside of the guard closest to the body, the width of the amount I want to widen the guard, approx 50mm. This would bolt up using the standard bolt holes, and then cut the remaining guard to weld to this extension, therefore widening the guard from the inside.
I can't seem to find anyone that has done this, or any info on it.
Has anyone had any experience with this that could provide some advice?
Cam
psimitar ·
Most peeps I've seen do it band the existing wings for 2 reasons. 1) cost of multiple pairs of wings 2) wasting a set of good wings.
But then the other thing to contend with is the compund curvature of the wings, especially the rears.
Those that I've seen widen the wings well have used an english wheel to put a curve into the strip so the widening looks factory. By doing the method you describe would require the join to the panel beaten to make the join look smooth and factory as again with the rears the curve is so tight on the top of the wing that there's not really a shallow curved area to place the cut within.
landfall ·
I thought of doing the same, but with the strip.
Local panel beater quoted me $1,000 a guard, roughly the same cost as the fibreglass ones.
RAW069 ·
psimitar wrote:Most peeps I've seen do it band the existing wings for 2 reasons. 1) cost of multiple pairs of wings 2) wasting a set of good wings.
Thanks mate, you make some valid points, def worth consideration. Cheers
RAW069 ·
landfall wrote:I thought of doing the same, but with the strip.
Wow $1000 per side??? Even that for fibreglass seems excessive?
What are others experience regarding cost?
Also worth asking where to source fibreglass rear guards in Aus.? I've been in contact with Paul Trani of eziglass who has moultds, but I'm having trouble finding out if these guards a widened and by how much. He is quoting $200 per corner which seems decent, if they are widened!
fish26 ·
I have a full set front and rear +40mm smoothie glass guards for sale
RAW069 ·
fish26 wrote:I have a full set front and rear +40mm smoothie glass guards for sale
Thanks mate, I'll have to finalise my measurements and check back with you.
I widen Austin Healey guards for a living, and I can assure you there is more to it than welding in a strip. Generally to do 4 corners and metal finish them is about 80 hours work at $100 per hour, so that makes it $8000, or $2000 per guard. It does take time, and the angles don't just fall into place when cutting and shutting the panels. I make new wider flanged edges with a new angle and weld them to the existing guard that has the existing flange cut off.
psimitar ·
Could also check out these guys in the UK https://www.facebook.com/Day-Mouldings-111149302304266/
They've been doing for years with excellent feedback on quality and fit. If you check out Transglobal express for freight you could be very surprised at the costs, in a good way 🙂
