Central Air Filter IDF's
https://forums.aussieveedubbers.com/threads/111594/central-air-filter-idfs
landfall ·
After asking here for some ideas I eventually decided to make a central air filter using easily obtained items, the main component, the air filter I obtained from eBay.
The air filter has 3" dia. intake and outlet which I reduced to 2" by using the silicone reducing hose also purchased from eBay. The other materials were 1.2mm flat and 2" exhaust pipe.
landfall ·
Because I was concerned about air flow into a 90degree change of direction I widened the entry point in the exhaust pipe. The flexible hose is the same as the hose supplying the air to the heat exchangers from the fan housing.
I also increased the height of the inlet box to 110mm for better velocity into carbs. To facilitate better sound proofing I also covered the housings with 10mm sound proofing with foil backing then applied carbon fibre wrap to the housings and pipe.
The difference was way beyond my expectations. Sounds like a standard Beetle now. Can actually talk to each other and listen to music.
The assembly is held in place by brackets attached to rivnuts in the fan housing.
grumble ·
That is impressive as you said the intake noise is normally horrendous and a stereo is wasted unless you play the "poor people doof doof music" and just feel the vibrations.
Yep - impressive
modnrod ·
We really need a like button........
sander288 ·
Awesome!
Love the carbon wrap over it too!
well done Greg, looks great
landfall ·
1303Steve wrote:well done Greg, looks great
Greg???
Didn't realize my late mother renamed me, I've been Ken for 71 years.
hahahahaha thanks for the compliment though.
Incidentally, I wrapped it in carbon to hide my very ordinary welding skills.
sorry thought you were somebody else
hulbyw ·
Great job!!
