Hi I have a 67 VW beetle, the type that the column, bearing is live but protected from ground.
My issue is I have had the column out of the car multiple times to try and resolve, I know that the column rubbers are new and insulating from body ground. The ground wire that runs down the steering shaft I have replaced twice to be sure it was not grounding inside the shaft.
The issue is I have a ground on the steering shaft piece between the steering wheel and the coupling and I should have no ground.
Is there something I have missed? I am loosing my mind trying to fix it.
If there are any suggestions or things I might have missed please do tell. Many thanks.
P.S I currently have a light globe where the horn would usually attach for testing. I have noticed when I turn the steering the globe will dim considerably in certain spots but never go out totally.
Here is a diagram of the steering/horn setups, mine is the 60-67
http://www.jbugs.com/VW-Tech-Article-Steering-Wheel-Horn-Diagrams.html
smithy68 ·
