wtb wheel studs for globes
https://forums.aussieveedubbers.com/threads/111648/wtb-wheel-studs-for-globes
tayloredvw ·
Im chasing 16 wheel studs/bolts for the use of mag wheels, like globes or hot wire wheels.
They don t seem available anymore.
Thanks.
Are they Cone shape or Conical shaped or flat faced
VVDS have all available and in different lengths
bushed ·
for what model? 12 volters are diff to 6es? length
tayloredvw ·
square faced, with 20-25mm thread into a 18mm thick shaft that is 20mm long then 50mm of 19mm hex head.
Its for a 4 stud 75 beetle.
bushed ·
so flat faced....or 90 deg to threaded rod...
Go to your local Bursons or any parts store and get some Nice Products 14x1.50 wheel studs part number is EX657, screw these into your hubs and then you can then use an appropriate shank nut.
the part number M600 has 17.1 mm shank or T 646 has a 18.6 mm shank so measure your wheels to see what size you need.
Im not a fan of shank nuts and bolts, they are awkward to use, my son had some shank type wheels converted to 60 degree nuts by a place in Sydney called Barrel Bros, they fit a steel insert into the wheel.
tayloredvw ·
thankyou Steve!
