SOLD SOLD SOLD Kombi / T3 / T4 70 to 2016 New Rear Brake Shoes
https://forums.aussieveedubbers.com/threads/111833/sold-sold-sold-kombi-t3-t4-70-to-2016-new-rear-brake-shoes
Calcool ·
Hi,
I have a new German set of Rear Brake Shoes. They will fit from 70 model Bay thru to mid 2016 T4 and T3 in between.
Thanks to 11CAB I now know these do not fit T4 I should not believe everything that is written on the box!!!
If fitting to a Bay you will just need to remove the self adjusting brake clip, or leave it on for the other models, you will be able to compare when you pull yours off. they also come with the drop arms for the hand brake. Often exchange shoes don't come with this and you brake the clip getting it off aarrgghh!
Save time with getting an exchange set, I bought these for a job I was doing and the Kombi did not need shoes in the end. I paid $65 for them so my loss is your win, otherwise they will go back on the shelf till I need them down the track.
$50 and they are yours
Im located South East Side of Brisbane.
David
11CAB ·
Hahahaha
Calcool ·
So 11cab you have broken a clip in the past???
11CAB ·
No, VW haven't used drum brakes on the rear of the transporter in 20 years......
Calcool ·
Good Pick Up I have not worked on a Type4, just went off the description on the box, maybe they do drum brakes in other countries???
11CAB ·
No, they'd only work up to 92.
I'd suspect the label may have been printed 07/16
Definately won't fit T4,T5 or T6
donn ·
$ to nsw. 2305??
Calcool ·
Sold!
