-Does Hella or any other company make replacement tail lights that are the same as original Country Buggy tail lights? If so does anyone have a source on where to get them or any part number for them?
-My CB has its tail lights but the rubber seals are cracking and weathered
-I see Hella also makes a license plate light housing but I am not sure if they are the same as the original CB housings. The replacement Hella ones I am referring to are part numbers 2557 and 2550.
My license plate light housing looks a lot like the 2557.
If anyone knows where I could purchase or if anyone has the following items to sell I am interested in buying them:
-Rubber seals for tail lights or full tail light assemblies
-Rubber seal for a license plate light housing or complete license plate housing
-Pair of Hella 2100 front blinker assemblies
Thanks!
CBKO294 ·
This is the Hella 2550 license plate light housing. I dont believe this one is correct.
CBKO294 ·
This one looks more like the one I have on my CB. This is the Hella 2557
The dimension photo wouldn't download properly but the dimensions are 108x44x40
CBKO294 ·
Hella 2100 turn signal housing
southspark ·
The 2557 is correct, just have to paint the silver bit black from the outside.2100 are still available both hella & aftermarket (crap quality).
regards Paul.
grumble ·
southspark wrote:The 2557 is correct, just have to paint the silver bit black from the outside.2100 are still available both hella & aftermarket (crap quality).
regards Paul.
From memory these No plate lamps were also fitted to the Morris minis in the 60's so you may be able to source one from a Mini enthusiast.
CBKO294 ·
Good to know that the 2557 is a correct replica.
It will be Hella for me on the front signals for sure. Only a couple bucks more than the cheaper ones. I was able to source both the 2557 plate light and the Hella 2100 turn indicators.
Thanks for the feedback guys. I had no idea the Morris used one so similar.
CBKO294 ·
I also sourced some Narva Rear Stop / Tail, Direction Indicator Lamps part number (Red / Amber)- Blister Pack
The part number is :
86010BL
Looks and size to be very close to if not exact to the OG Hella Tail Lights except for a chrome instead of black outter trim.
Hopefully they are the same size so I can use my Original Hella lenses in them.
Has anyone on here used these lights on their CB?
11CAB ·
Yep I have the Narva Tail lights on our CB. The bolt up to the original holes in the bodywork. And I got the front indicators from Supercheap with the LED's. They look original, but pretty bright when they operate.
CBKO294 ·
Great news and thanks for the information.
southspark ·
The mini lights were Lucas .The Holden 1 tonner come out with the same black Hella nu. plate light.
