The correct master cylinder (which I have) is a split kombi 22.2mm dia. and the plug screws into the cylinder whereas a beetle version is 19mm dia. and is push-in.
Thanks anyway.
regards
Robert
southspark ·
The rubber grommet is the same as any beetle, the steel tube is a push fit into it.
Regards Paul
southspark ·
Hindsight yes you are correct,splitty one is the one
Paul
bevoracing ·
A County Buggy has a 22mm like a Kombi but the rubber seal like a beetle. They are unique. You have to make a screw in fitting to do the job.
auditwmba ·
Thanks for all responses.
Internet, overseas and best local sources came to nil. I followed advice from VVD and used Pirtek for a good solution.
