Remove engine and gearbox together?
https://forums.aussieveedubbers.com/threads/112096/remove-engine-and-gearbox-together
KalgoorlieGreg ·
Hi all,
With the rear valance removed and everything electrical disconnected, is removing the engine and gearbox in one piece just a matter of unbolting axles and shifter connection, and the four bolts for the gearbox?
Cheers, Greg.
waltermitty ·
clutch cable, gear box mount
M
KalgoorlieGreg ·
Cool, would rather drop them together but didn't know if you could. Thanks!
too heavy do one at a time
KalgoorlieGreg ·
Copy that. Will listen to those who more than I.
HotRodMatt ·
An aircooled engine and trans is around 150kg, a clevo 351 on its own is over 230kg.
It's not too heavy if you are using the right gear.
HappyDaze ·
The only reason I can think of for NOT removing the engine first...is you don't have a 17mm spanner.
grumble ·
HappyDaze wrote:The only reason I can think of for NOT removing the engine first...is you don't have a 17mm spanner.
You got that in one Greg.
